FS-1128 scan lead edge cutoff.
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    u068 and u071 are on max negative, but the image has crept up even more since few weeks ago when the adjustment was done.
    Couldnt find QA, nor related documentation on this. Well there is one, but it says when "scanning position is off". Base on description of that QA the image is late, not early.
    Print is perfect however.
    any encounter on this?
    Idling colour developers are not healthy developers.
    • 23009
    Re: FS-1128 scan lead edge cutoff.
    Does it affect DF and OC images equally? How about scans?
    Just throwing this out there: Way back we had a couple of techs that liked to oil the photointerrupters (including scanner home position and registration). Genius at work. Oil is good for everything, yes? The result was scanner registration varying all over the place and slamming. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      Off the glass is ok, but by DF is consistently ahead by around an 3/4 to 1 inch by eye. It doesnt only happen on the first page, happens on every page.
      AND
      this lil' annoying glitch stays with the machine, doesnt follow the DF when we swapped it with another.
        • 23009
        If it stays with the machine, I would try the scanner board first, then the Main PWB. It sounds to me like you've already thought of that. =^..^=
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          next on the list fer monday.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1890
            The grease on the shaft of the scanner gets sticky & dry. I'd clean it with alcohol & oil it before doing any boards.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              ding ding, it was the main pwb.
              thx gents.
                • 23009
                Congratulations on your success, and thanks for posting back. =^..^=
