TASKalfa 250ci (sample)
  • TEC DOG
    • Sep 2011
    • 113
    Hello!
    I have TASKalfa 250ci with 90K prints.I bet on ITB but it looks OK.The same with all colours.Fuser is OK and toner is OEM.Please check samples. Thanks!!
    • 23009
    Re: TASKalfa 250ci (sample)
    OEM toner? It looks like developing to me, but not the usual. =^..^=
    • TEC DOG
      • Sep 2011
      • 113
      Wow! that was fast Cat!
      I hope you do not hear that often from your wife!
      OEM-Original equipment manufacturer
      I was thinking too about developer but 4 in the same time?
        • 23009
        It sure is unlikely to get 4 dev bad at the same time. But it just doesn't look like transfer. What do the U089 gray patterns look like? =^..^=
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1888
          I'm doing maintenance on a 300ci today. It only has 57k on color, but the developer oxidizes. That's why they list the cycles as 3 years or the count.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            how old is the machine?
            those looks like crack marks?
            Idling colour developers are not healthy developers.
            • JDR
              • Jan 2015
              • 82
              agree with blackcat -> developers
              wierd that 4 colors are shot in the same time...
              • TEC DOG
                • Sep 2011
                • 113
                approximately 4years.Did you mean itb cracks?
                • copydocinc
                  • Mar 2015
                  • 263
                  Just throwing it out there.
                  Maybe damp paper? Customer using a swamp cooler instead of air conditioner?
                    • 23009
                    I'm with tmaged on this. These developing units never make yield unless you are high volume 100% color. =^..^=
                    • subaro
                      • Oct 2010
                      • 1274
                      I would also try new set of paper and check density settings. stop print in just after enter fuser and see before and after. examine fuser.
                      Also, always put the machine in monochrome mode and check grayscale to start with. this will eliminate colour devs ect.
                      • jmaister
                        certified scrub
                        • Aug 2010
                        • 755
                        anybody checked the charge rollers?
                        or a really abused T belt + weak DVs?
                        • NeoMatrix
                          Senior Tech.
                          • 3513
                          I'd learn toward unused colour dev units binding up. Take them out and vacuum up loose toner outside the case. Give them a firm bump with your hand to loosen any binding dev an turn the dev roller by hand to check for even density.I've also seen something similar when coffee was spilt down the side of the machine an dried on the ITB.Only way to fix it was a new ITB ass'y.
