FS-C5100DN registration wonders
  • Gar the pilot
    • Jun 2025
    [CQ] FS-C5100DN registration wonders
    I showed my client how to adjust registration on her FS-C5100DN printer as it often wonders off. She just called to say it's way off and she wants me to come & take a look. None of my other color printers wonder off like this one, any thing I am missing?
    • 22999
    Re: FS-C5100DN registration wonders
    Worn transfer belt will cause this. Our fellow member tmaged told me about a product called Blow Off. He says it works well on transfer belts.
    This may be it: Private Label - Electronics Cleaner
    • Gar the pilot
      Belt Okay, Reg was off in both directions. had to go to "9" about 10 times to bring in side to side. top to bottem ( direction of belt travel) not off as far.
      Thanks G
      • ss12
        • 289
        There's a bulletin regarding this which involves sending a prescribe command to reset the registration so it doesn't keep happening
        • subaro
          • Oct 2010
          • 1274
          So what are the contents of this bulletin ? Is it this one that is found in this thread ?.
          Kyocera FS - C5300 DN color position shift and failure to adjust the colour regist
          • ss12
            • 289
            Can't follow that link
            • subaro
              • Oct 2010
              • 1274
              type kibbs on the search here and see the post by that fella. So you are saying there is a bulletin but not posting the number or the content. I understand some do not want to post the actual bulletins as the manufactures forbid the copying of their documents, but you can post the bulletin number and some brave warrior will look it up and post. Mentioning the bulletin number is not against the manufacture policy , but is rather beneficial to them.
              • ss12
                • 289
                http://www.copytechnet.com/forums/ky...ur-regist.html
                Think that this is the one yes.Its not that I don't want post the bulletin or its contents,it's just that I couldn't remember where I'd seen it
                • subaro
                  • Oct 2010
                  • 1274
                  Not remembering is not a sin and is a valid answer. Thanks for replying though. kyocera firmware fix and registration tool does not fix this for me, yes that't the one they still have on their connect website. doing the registration multiple times untill it is stable is the only way i have got this to work. transfer belt and the rest menitoned does not solve this problem. only thing i did not really pay attention to is the patch sensor shutter someone mentioned.
                  Kyocera has not come clean with this problem as to a definite resolution to this rather annoying problem.
                  • ss12
                    • 289
                    whats the date on the firmware? The latest in the uk is dated 4-30-2015
                    • subaro
                      • Oct 2010
                      • 1274
                      Both the 5100 and the 5300 are. You are definitely positive about that date. check again please and mention which model you are referring to.
                      FS-C5300DN Combined Firmware 03/11
                      FS-C2626MFP Combined Firmware 05/14
                      • ss12
                        • 289
                        Its for the fsc5100-5350 send me a pm with your details so you can take a look.i'll send them tomorrow at some point
                        • subaro
                          • Oct 2010
                          • 1274
                          Thanks for your offer. I visited the kma website and saw the fs-5350 firmware as below
                          FS-C5350DN Combined Firmware 08/15
                          Is the 5100 and 5350 using the same firmware ?. What is the lastest f/w you have listed for the fs-2626. just want to see if the uk and north america has different versions.
                          FS-C5100DN
                          3 Measure for a color shiftadjustment failureEven if automatic color registration adjustment is performed, the color shiftadjustment may fail. This has been corrected
                          [ This is 2011 f/w]
                          MAIN 2K8_3000004005 - 004.005ENGINE 2K8_1000007001 8C06 007.001 FS-5350DN
