Kyocera Taskalfa 300ci
  • aAandy
    • Apr 2012
    • 369
    Hello people
    this machine says it cannot do double sided scans due to a fault with the document feeder - how do i find out what the fault is?
    the ADF has a scanner built into it to scan/copy the 2nd side, in other machines this scanner is electrically separate from the rest of the ADF and i presume the same in this machine as the document feeder has two connectors plugged into the machine
    any assistance greatly appreciated
    thanks in advance
    Andy
  • MCC-support
    • Jul 2014
    • 38
    Re: Kyocera Taskalfa 300ci
    Originally posted by aAandy
    Hello people
    thanks in advance
    Andy
    The machine locks down functions of the machine if there are recurring issues in that part.
    May have been multiple jams in the ADF and the machine has locked it.
    Run U906 and powercycle the machine. Then do a scan to test, either the issue is still there and you'll be able to find it or it was just a once off for whatever reason and it'll be fine.
      • 22930
      It's a fairly common failure on the DP-760 to have the CIS cooling fan fail. The resulting heat buildup in the DP causes the CIS to fail soon after. As you probably already know its a very expensive part to replace. The resulting code is C3210, which you can observe on the Event Log (Service Mode > U000 > Start > select Event Log > Start > Stop x2 > to exit: 001 > Start. =^..^=
      • blsquires
        • Nov 2008
        • 342
        make sure the hard drive is ok .they have a habit of stuffing up on these machines
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1858
          Clean the white roller opposite the CIS. The CIS uses it for white reference. If it's dirty, the machine assumes the lamp isn't lighting bright enough. 906 after cleaning it will resolve the issue.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
