Code c2600
  • rbell12
    • Aug 2006
    • 83
    Code c2600
    Getting intermittent c2600 code on km-5035
    checked operation of each tray for smooth lift
    checked connections from motors and boards
    checked gear trains for cracked gears
    reset 906 and tested tested
    ran for week code came back
    any suggestions would be helpful
    thanks, csc
  • guru
    • Aug 2006
    • 18
    thanks, csc
    The code is related to the left cover safety switch. It's has 3 switches in one, if one of them is not closing right the code will pop up. Make sure the left cover is closing OK. Sometimes finisher pulls cover away a bit.
    not outsourced yet ...
    • 10871087
      • Jan 2005
      • 1062
      I have seen the same problem/fix once before about a year ago on a KM-3035
      • rbell12
        • Aug 2006
        • 83
        thanks for the input. we ended putting new motors on both trays and it seems to be working, but, if this comes up again i will check the suggested switches. thanks again for the suggestion. rb
        • digicor
          • Jul 2008
          • 1159
          HEY DUDES
          IT WAS THE LOWER DOOR OPEN JUST A TINY BIT, NOT CLOSED ALL THE WAY. i ASK THE CUSTOMER TO CHECK THIS OVER THE PHONE,SHE SAID SHE DID THAT,HAD TO GO OUT, CUSTOMER OUT 109.00 H HE HE
          LOVE A BILLABLE WITH NO SCREW TURNING....
          • Craigdumass
            • Jun 2009
            • 61
            The machine must have some kind of jamming problem when the customer removes the jam then they are not closing the left cover correctly. I would check your jam codes to find out why that cover is being opened and closed to remove the jams.
            • digicor
              • Jul 2008
              • 1159
              well yes it was the lower door not closed all the way on my cust 3530
              she got billed, i got paid, no screws were turned, its a nice day..
