Zeus is kicking my ass again.
    • 22999
    It's a KM-8000i that started out with J4913 jams. When it first started it would jam once or twice, then print several thousand. I seems to be getting worser and worser. It will no longer pass any paper.
    Early on (3.5M prints), I had changed the conveying rollers, paper feed flags & springs, and decurl roller. Today I changed all the photointerrupters in the bridge. When I arrived there was a J4914 jam that would not clear. After changing the sensors I got C1410 and J0132 jams (de-curl rotation error). If I go into U031, BRSW2 will randomly appear blocked or unblocked. Just to be sure, I installed 3 more photointerrupters with the same result.
    So I've got all three sensors in the bridge randomly changing state. It's possible, of course, that the engine board is bad but I'm leaning towards the bridge controller as the culprit. It's the randomness that bothers me. Has anyone seen something like this?
  • wragsdale
    • Jul 2014
    • 188
    Re: Zeus is kicking my ass again.
    All of our high volume 8000i's have already been replaced and none of them exceeded 4M. I haven't seen issues as systemic as you've described but I have witnessed some inexplicable bridge sensor behavior.
    In one case with a persistent blocked sensor I disassembled the bridge, found nothing, and the problem seemed to disappear. No recurrence though and it's unlikely that it was caused by either PWB. In your case though, your hunch (BRMPWB) seems the next best step!
    • Kyo fan
      • Dec 2013
      • 368
      We don't have any of those over 2 mil yet, so the headaches are bearable. Looking at those C1410 and J0132 jams you have, there's a bulletin on it, where you replace actuator + stopper as set:
      PARTS ACTUATOR PRESS SET SP (302LF94520)
        • 22999
        [ATTACH=CONFIG]31390[/ATTACH]
        Thanks for the information Kyo fan, but I'm not that worried about that actuator coming off. Sure it currently does not have a clip, but it's behind the copier's exit section frame, and it would take dynamite to blast it past the exit section. It can't really escape. I've had that drive unit out four times Thursday, so I am intimately familiar with it.
        I'm really getting irritated with this machine. Still waiting on the bridge unit controller PWB. =^..^=
        • Iowatech
          Not a service manager
          • 3930
          Does the bridge unit has interlocks on it? There were a few on Ricohs that the actuators for those interlocks were not quite long enough, they caused random jams until I built them up with double sided tape.
          Sorry if that was a waste of time.
            • 22999
            I did give it some thought, but it's not a particularly easy theory to test out. I think I have a picture:
            Do you see the ground spring on the front of the drive unit? About 39mm to the right of that you can see the plunger of the bridge interlock switch. It does change state from infinite to 0 ohms. This particular switch does not appear in the U031 sensor diagnostics. It is directly behind the bridge unit, so you cannot see it at all with the bridge closed. Additionally, the only place you could pin out the switch is on the bridge unit controller, trapped between the back wall of the copier and the back of the bridge unit, completely inaccessible. I can be fairly certain that the interlock is being made though. When the MFP is in one of it's moods, BRSW2 shows blocked any time the bridge unit is inserted (and the interlock made).
            I think I've got that one covered. Thanks for the ideas. =^..^=
              • 22999
              The bridge unit controller + (3) new photointerrupters seems to have done the trick. It ran 1000 duplex without a hitch. I'm going to cross my fingers and wait. =^..^=
                • 22999
                Back again today. It was better though. (6) jams in 24 hours. I thought since I had pretty much exhausted the bridge unit investigation, maybe I'd look at the exit assembly. Here is the exit sensor flag:
                With the right door off, I could see that the exit sensor just barely moves because the flag is so worn. I don't have a new flag to install, but a fairly simple MacGuyver seems to help. The original flag is sandwiched between two layers of plastic, glued, trimmed, shaped, and smoothed. A little additional trimming was required to get the return spring installed.
                I printed a couple thousand without a jam ... just like the earlier visits. Time will tell if it makes any difference =^..^=
                • NeoMatrix
                  Senior Tech.
                  • 3514
                  The MacGuyer flag repair looks like a winner. You could be onto the problem.
                  Is the exit ass'y warped or out of plumb ? Check it on a flat surface or platen glass.
                    • 22999
                    It looked surprisingly good. I've seem plenty of Sharp and Kyocera delivery units that warp and crumble from the unrelenting exposure to fuser heat. =^..^=
                    • tmaged
                      Owner/Service Manager
                      • Oct 2008
                      • 1869
                      QA_201307_D148-2LC-0123.pdfNow that you post that, I do recall our Kyo rep mentioning sensors wearing down on high volume machine causing jamming issues. I don't however remember a bulletin regarding it. I'll see if I can locate one.
                      Edit: I attached the only one I can find.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                      • monstott2010
                        Sounds like you may have it taken care of, but just in case, here's another thread from a while back, similar issues, maybe helpful, maybe not.....
                        http://www.copytechnet.com/forums/ky...18-5011-a.html
                          • 22999
                          Thanks monstott. Today was the first time in a week that I didn't start the day at that machine. I'm keeping my fingers crossed. =^..^=
                            • 22999
                            Just to follow up, there have been a total of (4) paper jams in the last 200K, none of them in the exit or bridge. I'm going to take that as success. I do carry the flag now, so I can retire my MacGuyver'ed sensor flag the next time I have the fuser out.
                            The sister machine is at 1.99M already. I'll be watching for the bridge jams.
                            I noticed something interesting on the PF770 LCT last visit. I don't know if it's just their paper, but if you stack the whole 3000 pages in there, the ends of the stack are a full 12mm higher than the center. As a result the paper tends to jam and flip corners. If you only stack it to 2000 it's fine. As an experiment, I cut some corrugated cardboard 8.5" x 6.5", 8.5" x 7.5", and 8.5" x 8.5", then stacked them up smallest at the top, and taped the whole mess to the lift plate. Now the whole stack sets perfectly level at 3000 pages, and has about a 9mm crown by the time you get to the bottom of the stack. This doesn't seem to cause any kind of a problem.
                            I don't remember encountering this problem on the other Kyocera LCT's (PF-650, PF-660). Maybe this is why Kyocera typically does not try to stack 3000 to 4000 sheets in one pile. Because it usually ends up not being a level pile. I seem to recall addressing this same sort of issue on an HP LJ9050, not because it was 3000 sheets, but because they were printing onto flat foldable window envelopes, and the additional layer of clear plastic thickened up the one side of the stack considerably. I seem to recall making a wedge shape to even up the LTR stack so it would feed. Has anyone else addressed this? =^..^=
                            • ccfc87
                              • Feb 2014
                              • 18
                              We have a 6651ci with intermittent C1410. De curler motor error
                              A new Exit unit above the Fuser and Exit Unit from Bridge to Finisher has been installed. A new Bridge Unit and Bridge Unit drive assy too! the sensor actuator mod from 2014 has also been done....Running out of ideas other than engine board now.
                              Any suggestions appreciated.
