0533 and multifeed all the way through
  • Jii
    • Jan 2016
    • 6
    [Jamming] 0533 and multifeed all the way through
    Hey. Ive got a 5551ci taskalfa that is popping a lot of J0533's.
    The jam code means cassette 3 (high cap) is multifeeding.
    Upon further inspection, its pretty wild, but if it doesnt jam it will actually pull two all the way through the machine. It will fix the toner properly and everything, but as your watching it collate on the finisher as it comes out it, it will literally have a blank piece of paper attached to another piece because it is literally double feeding successfully all the way through.
    So clearly it is unable to properly separate or succesfully retard the next sheet from coming through.
    I've replaced the rollers, and now the entire paper pick up assy (thats what its called in canon, not sure of the kyocera nomenclature)
    Also the machine only has like 20k on it.
    So with the paper pickup assy replaced idk what it could be.
    I have an entire new cassette (deck) ordered now. Because i know in canon on some models the cassette itself actually actuates something that causes the sep roller to come down and do its thing. But i may be barking up the wrong tree.
    Hoping to find someone who has any ideas. Thank you.
  • Lunatech
    • Oct 2012
    • 208
    Re: 0533 and multifeed all the way through
    Well?
      • 23008
      tmaged has experience with this issue. His latest experiment has been to install Alphard I feed units into the Alphard II machines. I don't know if this also apples to the LCFs. Is there any sort of separation adjustment? =^..^=
      • Santander
        • May 2009
        • 768
        It sounds like you have a faulty torque limiter for the retard roller. The torque limiter alone provides the resistance for the retard roller to separate the sheets and if it is allowing the retard roller to turn this would account for the multiple sheet feeds. There is no adjustment for the retard roller. We have sometimes just cleaned the limiter to solve the problem otherwise just replace it to be sure.
        • tmaged
          Owner/Service Manager
          • 1887
          Since I put the Alphard I feed units into the LCC on the 4501i that was giving 0533 & 0534 jams, not a single one. I've got the torque limiters on order. Those damn things are half the price of a complete feed unit. I just have trouble believing that both could be bad, but it's definitely not the drive pack.
          And there is a pressure adjustment on the Alphard II feed units for separation pressure.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
            • 23008
            Have you had any success with changing that separation pressure?
            • tmaged
              • 1887
              Adjusting the separation pressure did not affect the jamming.
              Hope that helps !
              -Tony
              www.dtios.com
              • Tulsa
                • May 2014
                • 20
                Jii, Anytime that we are having a tough to discover issue with J0533s we do a thorough check of the right end of the unit and makes sure that ALL and I do mean all of the cover screws are in place and secure. If you ar missing one of those screws, very difficult to troubleshoot anything else. Not sure where i read this but it is invaluable information. good luck!!!!
                • Lunatech
                  • Oct 2012
                  • 208
                  I don't know why or how but, changing the door just above the pf door fixed it on mine.
                  • Jii
                    • Jan 2016
                    • 6
                    Thank you, is the torque limiter for the retard roller part of the pick up assy?
                    • tmaged
                      • 1887
                      My ASM just sent bulletin G198. It addresses the clutch stopper in the frame being to wide. The clutch spins & smacks the frame breaking the copper wires inside. It says it can cause either no feed or multiple feed jam codes.
                      The torque limiter fixed my issues.
                      As a side note, if you read the bulletin on the feed units with the spring adjustment, less spring pressure equals more separation strength. I noticed on the new boxes, they went back to a wrap spring torque limiter. I guess the magnetic ones weren't as good as they thought.
                      Hope that helps !
                      -Tony
                      www.dtios.com
