So how are the TASKalfa 4550ci, reach PM cycles, run good or ???
  • CCS
    • 266
    I'm thinking of picking up the service on a couple of 4550ci/5550ci , they have around 350-500k on with color and blk/white meters split about in half.
    Is this a good box or should I stay away?
    Will they make it to the 600k PM cycle?
    How long will the fuser go?
    Toner yields OK?
  • jhalfhide
    • Apr 2015
    • 451
    Re: So how are the TASKalfa 4550ci, reach PM cycles, run good or ???
    We found toner yields to be an issue so we stopped the service on our Kyocera's. Transfer belts and fusers seem to last forever if you run them to life though.
    • wholesaler
      • Jun 2015
      • 20
      Toner yields OK?
      very rarely do they make it to the pm cycle but they warranty the machince for 600k so you can get credit for the parts that dont last the 600k
        • 22985
        The rollers fail around 100K ... unless you sub in the standard Konica Minolta rubber. I'm getting better yields from them. =^..^=
        • Daveyboy
          • Feb 2011
          • 18
          • Ctl-Alt-Del
            • Jul 2006
            • 430
            I'm a fan of the machine and an even bigger fan of the newer xx51ci series, they are generally profitable units for us.
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              In comparison to TA250ci to TA500ci, way better.
              Drum/developer rarely fails but the main charge tend to swell after 300,000 or earlier. Feed pulley as Blackcat said doesnt last til 300k.
              Fuser tend to fail. Well, kyocera fuser tend to fail, its the norm.
              Idling colour developers are not healthy developers.
              • CCS
                • 266
                Are there any differences between Taskalfa 4550ci and Copystar 4550ci ?
                • tmaged
                  Owner/Service Manager
                  • 1864
                  None at all. Change the badge & sim and it's a Kyocera.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  Become a fan on Facebook
                  • jhalfhide
                    • Apr 2015
                    • 451
                    Yep, as tmaged said they are exactly the same. As are Utax.
