TASKalfa 6550ci
  • RoyROd
    • Mar 2013
    • 29
    [CQ] TASKalfa 6550ci
    I am working on a Kyocera TASKalfa 6550ci, that will not print clean prints, we have changed fuser, the IH Unit as well as updated the firmware, don't know how many times. While Plain paper comes out filthy, the toner will streak across the pages, it is at its worst when using a high quality paper, like glossy or cardstock. All basic settings when printing have been changed, such as choosing the media type and such.
    I'm at my wits end and our normal tech support has run out of suggestions.
    Has anyone here run into a problem similar to this?
    • 23009
    Re: TASKalfa 6550ci
    What paper specifications exactly? Glossy paper is a headache for EVERYONE. Sure, there's a "Glossy" media setting, and it works OK on semi-gloss media but not on full-gloss media. It's just too slippery, and the clay in the full gloss paper will coat every roller in your machine. You'll be cleaning rollers daily, with only short term success.
    My suggestion is to convince your enduser that it's in everyone's best interest to run semi-gloss medium weight paper. How will you do that? I surely don't know. I haven't had much success in that department. I just get dirty looks, and " ... the salesman said it would do full-gloss 250gsm ... " like that.
    Sure. If you say so it's a printing press, not a photocopier. =^..^=
    • Ctl-Alt-Del
      • Jul 2006
      • 430
      Re: TASKalfa 6550ci
      First question is: Where is the dirt coming from, I'll assume since you only mentioned fixing area you have ruled out everything else. Other than that I'm with Blackcat because Kyocera has always been a little lacking in the color fusing department, especially on heavy coverage or glossy, heavy stock. What type of jobs are they running or is it everything out of the machine?
