KFS machine registration
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1897
    I've found that if you're setting devices up on KFS, you'll get a network error when trying to register the device if DNS doesn't match the network exactly. I'm not sure why, as DNS will resolve the email host name as well as web browsing will work, but they have to be in the exact order that DHCP assigns them to a network adapter.
    Example: the MFP had 8.8.8.8 as primary DNS & 192.168.1.1 as secondary DNS. I could do all functions on the internet properly, except register the device on KFS. ipconfig/all gave me 192.168.1.1 as Primary & 8.8.8.8 as secondary. Changing the MFP to these specs & rebooting allowed it to register the device.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • 23010
    Re: KFS machine registration
    Interesting! Thanks for sharing. =^..^=
    • just a tech
      • Jan 2007
      • 332
      Haven't had this issue yet, but will keep an eye out for it..
      Thanks..
      JaT
      • narnol02
        • Oct 2013
        • 11
        • Xer0615
          • Jan 2019
          • 48
          I had a similar issue with KFS the other day. DRDT would state that it was registered, but the machine clearly was not. upon calling Kyocera they informed me that they were experiencing issues with the server. The next day I came back and was not having the same issue. Barring the same server issues, did you try wiping the KFS registration on the machine? I forget the simulation number, but the service reps always suggested initiating it when troubleshooting. You can also use DRDT to UNregister a device, which might be worth a try.
          • Dougie179
            • Apr 2019
            • 12
            Maintenance Mode U520, Configuration - Off, press start button, follow screen prompts
