TaskAlpha 3051ci Leaving Strange Lines
  • ntbann
    • Jan 2012
    • 628
    [CQ] TaskAlpha 3051ci Leaving Strange Lines
    I have this machine leaving four light lines sporadically. I measured the distance and it is drums. Just wondering if anyone else has seen this?
  • wragsdale
    • Jul 2014
    • 188
    Re: TaskAlpha 3051ci Leaving Strange Lines
    Is this happening only to your copies? This HAS to be a occurring at the optics. Those are RGB (plus void) bands which would indicate some kind of refraction. For the print engine to be responsible for this, it would take a very specific set of highly unlikely circumstances.
    • ntbann
      • Jan 2012
      • 628
      That is a print. Hence the confusion!
      • wragsdale
        • Jul 2014
        • 188
        In that case, you should try to isolate if the problem is occurring at the print engine or image processing level. I honestly have no good explanation for this other than something to do with the LSU. I would, at the very least, run the cleaning option from the maintenance menu and if that does nothing, pull the LSU and visually inspect.
          • 23008
          I suspect a shorting or discharging black drum unit. The simple way to diagnose this is to swap the black drum unit with the magenta drum unit, then print something like this: =^..^=
          • copier parts n.ireland
            • Nov 2016
            • 41
            i had something close to these rainbow bands on the the utax 3005ci equivilent,lsu cleaning would fix for a while,im suggesting to customer its condensation on lens on lsu. i have installed a cassette heater to copier and no repeat call yet.let me know how you get on.
