2551ci
  • big jase
    • Jul 2008
    • 136
    [CQ] 2551ci
    I have a strange fault appeared on print/copies outs all colours mixed up also on mono prints/copies
    i have attached samples from internal prints
    could it be HV? or are we looking at a PWB?
    If at First you don't succeed remove all evidence of ever trying!
  • Tonerkiller
    • Oct 2012
    • 668
    Re: 2551ci
    I had one like the second image. There was an area on the drum that the coating came off.
    • copier parts n.ireland
      • Nov 2016
      • 41
      Re: 2551ci
      we had this problem once on utax 2550ci,we changed every single circuit board and still coudnt cure,we had to return copier to utax swindon,if memory serves
      2 circuit boards had to be changed and same time in back of machine,will try to look up old service record to see which 2 boards.hiv and main ??????..steven irvine
      • KYO_OEM
        • Aug 2011
        • 721
        • Alexkyocera
          • Jul 2015
          • 82
          Re: 2551ci
          I know exactly how to fix this PM me right away for fix.
          • Kyo fan
            • Dec 2013
            • 368
            Re: 2551ci
            Good for you. In that case, feel free to post the solution here and help others that might come across this.
            • Alexkyocera
              • Jul 2015
              • 82
              Re: 2551ci
              Hi KYOFAN,
              I'm not being selfish I swear to you, just being a little cautious,I rather the person with the issue try whatever I told them and then come back and said it worked. It's less to filter through just incase some else had the problem they have to be reading through this while heap of threads, just ridiculous. Anyways
              Fix:
              The customer will have to replace the Developer units one by one, starting with the Cyan.
              NB: one of the developer units are Arcing and this the cause for the image quality uploaded by the client. *fingers crossed*
