firmware questions
  • COPYDOCAZ
    • Mar 2015
    • 110
    [Misc] firmware questions
    Need to update firmware on a 305i, went to the website and saw 2 versions one said TURBO is this a faster version or what. Generally I go by the latest release date but there the same.
    • 22999
    Re: firmware questions
    The difference between the Turbo and the Regular firmware is that the Turbo firmware will only update the individual firmware files that changed. The Regular firmware overwrites all the files whether they are the same or not.
    So lets say that you've got corrupt engine firmware. If you use Turbo and the file name is the same, it will not update it. Personally the difference of a few odd minutes is negligible, compared to the memory requirements of carrying twice as many firmware files. I only download and use Regular firmware, but it's up to you. =^..^=
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1869
      I keep all turbo versions on my laptop for every machine. You'll only need to remove the es_skip.on file to make the turbo firmware a full firmware. Turbo is a lot faster in most instances, so it's my first choice.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
