Stop machcine
  • ntbann
    • Jan 2012
    • 628
    Stop machcine
    Just wondering if there is a way to make a TA8001i stop operating when it is time for maintenance?
    • 23009
    Re: Stop machcine
    It's not in the standard simulations AFAIK. There might be something in special service mode, but I don't know how you'd get there. I think I'd contact my tech rep. =^..^=
    • Santander
      • May 2009
      • 768
      Re: Stop machcine
      Is there a reason you want the machine to stop working when it reaches the PM count??!! There is nothing I know of in the special service mode that would disable the machine, again why would you want that? We use the time for maintenance indication to schedule the PM for a slow day rather then create an emergency call. If the unit is operating without a problem why would you want to create an emergency when you could do at your convenience? Did a PM on a unit just yesterday that the customer had called in with a time for maintenance display 10 days ago, unit was operating fine with good copy quality and we were able to perform the PM on a slow afternoon. I am sorry, but I do not understand why you would want to shut down a working unit just because it has reached the PM count.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1888
        Re: Stop machcine
        Some schools will let the maint cycles run way over, voiding the warranty. As long as it's still running, they don't call. I've got all of our machines in KFS set to email all of our techs when the maint lights come on. You could also set it up in the machines to email you directly as well.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • ntbann
          • Jan 2012
          • 628
          Re: Stop machcine
          You got it right. It's a school district!
          • habik
            • 2013
            Re: Stop machcine
            I don't get it either. If the machine runs fuser for argument sake to 400-600k . Then you should be happy and manufacturer as well. If it fails under the PM cycle and school will call you then you warranty it. Are you putting paper feed tyres through warranty's or how often does this happen that you get void on warranty. Just trying to find the logic behind it.
            Cure to the problem has been said by tmaged.
            Option 2:
            Schedule a visit every month print Maintenance reports from each machine and analyse in workshop, then grab parts and return at your leisure.
            Byting on bits.
            Firmwares HERE
            • ntbann
              • Jan 2012
              • 628
              Re: Stop machcine
              What's not to understand. One lost warranty is a lost warranty. It costs us money!!!!!
              • darry1322
                • Oct 2010
                • 817
                Re: Stop machcine
                We recently put a school system under KFS and found 6 machines that were due maintenance kits that hadn't been called in.
                Now we just check KFS every morning to look for issues.
                • habik
                  • 2013
                  Re: Stop machcine
                  OK. Are you saying your Drum suppose to last 600k, you get 500k out of it develops a fault, you warranty it and they send you new drum. What do you supply to manufacturer and how much credit do you get for your part? Full 100% or just for those 100k that your old drum supposed to do? You can PM me if you want.
                  Sent from my iDon't believe in marketing device using Tapatalk
                  Firmwares HERE
                  • eddie110171
                    • May 2012
                    • 133
                    Re: Stop machcine
                    You have to track meters to bill. Do the same for maintenance. If you have e-automate set the maintenance tracking and it will alert you.
                    • tmaged
                      • Oct 2008
                      • 1888
                      Re: Stop machcine
                      You get 100%, doesn't matter where it's at in the maintenance cycle. If you don't change it within the 10%, it voids the warranty.
                      Hope that helps !
                      -Tony
                      www.dtios.com
