I'm getting a repetitive CQ issue that points right to the charge roller, as it measures 30mm, tho random, but it isn't the roller. I've swapped them. The drum is rather new, replaced a week or so before. I'm not seeing anything wrong with transfer roller, dev roller or any other. I could just start swapping all of them if I had them on hand but I'd like to avoid that if anyone else has seen this issue and what the fix was.
M3540idn CQ issue
Re: M3540idn CQ issue
It looks like the black drum to me. Whichever charge you put into the black unit will still arc to the drum if the coating is worn through. You should be able to see it. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
