Kyocera FS C8520 MFP Jamming in Vertical Transport
  • docfeeder
    • Aug 2015
    • 12
    Hi All
    I have an issues with jamming in the vertical transport section on a Kyocera FS C8520. I have cleaned the vertical sensor. The paper gets to the transfer belt/ transfer roller and then just folds and jams in that area every time. I have run up the machine with the door open and noticed the transfer belt either does not turn or stops/starts in a jerking movement. The drive motor turns, so I am guessing the problem is in the drive assembly or clutch?
    Has anyone else had this problem ? Is it a known issue ? And do you have to replace the complete drive assembly?
    Kevin
  • KdvA
    Engineer
    • Aug 2008
    • 10
    Re: Kyocera FS C8520 MFP Jamming in Vertical Transport
    most likely a defective "middle transfer drive shaft".
      • 23010
      jam code? =^..^=
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1890
        http://www.copytechnet.com/forums/ky...lding-jam.html
        The search function is your friend.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • serviceman678
          • Sep 2016
          • 19
          Originally posted by docfeeder
          Hi All
          Kevin
          check the toner recycling system if the auger get jam this will happen also if the fuser doesnt come to the proper temp this will also happen but you need a spare fuser for
