new to the Kyocera MFP's
  • dwarf
    • Oct 2012
    • 168
    concerning the TA 3501 with fax...this customer has incoming fax go directly to a folder...no print-out report for send or receive... is there a way for the customer to monitor the fax queue to see which faxes did not get transmitted? ... we are new to the Kyocera ... thanks in advance for your help...
    • 23009
    Re: new to the Kyocera MFP's
    You mean like the job log? I'm pretty sure you can view that from the Command Center. =^..^=
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      If I recall under Job Status/Cancel on the Sending tab I believe you can print a job log somewhere...not 100% sure but worth a look....
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
      • 20gaugeO/U
        • 557
        Status/Job Cancel --> Fax --> Menu --> outgoing fax report print
        I don't have that model but this is close... if that's what you are looking for
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1889
          If a fax was unable to be sent to the folder or email for any reason, you get an error code at the MFP & the page will print once you acknowledge it. They will never get lost.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
