Copystar CS 2550 Ghostning
  • Riviera
    • Sep 2016
    • 66
    I have a Copystar 2550 driving me crazy. Toner is sticking to Fuser causing ghosting and overall crappy copies. I put in a new maintenance kit , it was due, and still same issue. I tried another transfer roller, another developer , another drum, another fuser , Raising fuser temp, lowering fuser temp and three different toners. And yes OEM Toner. I saw something about a new style fuser roller? Counting the fuser that was in before I started, three fusers all causing same problem. And all fusers are OEM and purchased in last year. Anyone run into this before? If so please , any help or suggestions would be appreciated.
    • 23006
    Re: Copystar CS 2550 Ghostning
    Anything special about the media? =^..^=
    • Riviera
      • Sep 2016
      • 66
      Plain paper. And when I change to heavy , thinking a little slower and more heat would help, it was worse
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1879
        Firmware up to date ? I recall something in a firmware that fixed that, may be a different model though.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Riviera
          • Sep 2016
          • 66
          It seems the center of fuser is the worse. Towards ends it stays clean. The fusers throughout the last few years they had the machine, always crapped out early and all were due to the roller coating. But a new fuser would fix problem for a while. This time , no.
            • 23006
            What about fans? Are they all running, and blowing in the correct direction? If you have a thermocouple you can check the internal temperature of the machine on longer runs. I would expect it to stabilize around 85F internal, depending on where you place the probe.
            As an experiment, you might remove the covers from the left side of the machine and run a few. =^..^=
            • Riviera
              • Sep 2016
              • 66
              Firmware hasn't been updated. I left them a loaner to give me some breathing room. And planned that as my next step.
              • Riviera
                • Sep 2016
                • 66
                Thanks guys. Ill check fans and update firmware.
                Ill let you know if it worked
