TA300ci 39mm spaced lines feed dir
  • John Alldrick
    HATED COPIERS for 40 yerz
    • Mar 2010
    • 5
    [CQ] TA300ci 39mm spaced lines feed dir
    Black only, sporadic, identical lines 39mm apart, regardless of paper tray or orientation.
    Enclosed Image was darkened x3 on scan for contrast
    Full colour images look GREAT except for above.
    I don't believe any relevant previous service - only feed / fuser issues - Maint / F-W(v16) all current & not recent
    my first post- sorry for any protocol errors, folks
    Any thoughts anyone ?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1896
    Re: TA300ci 39mm spaced lines feed dir
    The main charge roller is 38mm according to the guide. That's where I'd start. Easy enough to switch with another color.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23010
      I'll agree with Tony. My guess is that you've mis-marked the leading edge, and this paper ran LTR. =^..^=
      • John Alldrick
        • Mar 2010
        • 5
        Actually I thought I HAD lost track of orientation, so I removed all except Letter R in machine - the little mark at top was marking lead edge in tray before printing ...
        to be more accurate, image is about 39.5 mm apart - Manual says chg roller is 38mm - and when I thought I was nuts, inspection of chg - only rub lines in feed direction - swapped with cyan anyway (to make sure I'm not as dumb as co-workers claim) - no change
        Letter cross (LEF) shows same image repeated all the way across Frt to RR - 11x17 identical & goes all the way down - no repeat image - just similar
        and every page (10/10) is identical - marks do not change or move at all - EXACT same pattern & location on every page ???
        1 out of 100 copies was w/o marks first 1/2 page - just my 'lead edge' mark
        I suspect the 'repeat' pattern is from the LPH laser controller processing or print control PWB - Have re-seated LPH harnesses back to imaging board - Maybe arcing somewhere ...but then pattern would change ??!!
        Guess it's time to 'Swap' parts, but don't have any inshop ...
          • 23010
          Did your scan skew a little? My guess is yes.
          If you copy or print a pattern of fine vertical lines in the feed direction, do they waver/wobble? The test pattern that I attached may help. If yes, it is probably the laser. Perhaps there is a minute fiber dangling from one of the black laser mirrors, and blowing around in the air vented from the laser. It's not a very big deal to clean and examine the laser.
          You can reasonably rule out drums, developing units, 1st transfer, 2nd transfer, drive components, all because it's nearly impossible to get a wear pattern like this in the feed direction, exactly at 39.5mm intervals.
          Maybe a Main board, maybe re-seat memory, maybe star wheels on the fuser or primary transfer belt.
          Come back and tell us about it. I'm interested. =^..^=
