FADED IMAGE
  • dakwest
    • Aug 2025
    [Misc] FADED IMAGE
    I have a Kyoceta KM6550. Having trouble with the image fading...especially the black. Whenever a solid is printed, the lead edge is solid for about 1/16" and then the balance is faded. Thinking it is an electrical problem. Any ideas?
    • 23009
    Re: FADED IMAGE
    Sample? =^..^=
    • DDlan
      • Mar 2017
      • 26
      Re: FADED IMAGE
      you should be post copy
      • dakwest
        Re: FADED IMAGE
        Here is an image. It does this on all colors but it is most noticeable on the black.
        • dakwest
          Re: FADED IMAGE
          Sample? =^..^=
          Here is a sample. It does this on all 4 colors but is most noticeable on black.
            Re: FADED IMAGE
            Thanks for the sample.. what have you tried so far? Seeing how it is on all colors... pull the toners/drums/ITB thoroughly clean the inside contacts ITB sensor ect.... how old are the dev units? Drums/Belt?
              Re: FADED IMAGE
              is this in copy mode or print? What do the internal prints look like?
              • Ropariva
                • 680
                Re: FADED IMAGE
                Looks pretty normal for a Kyo of that series. Devs are supposed to last 600k but can show fading and degradation in as little as 200k. Try a new dev.
                  • 23009
                  Re: FADED IMAGE
                  Even with completely new supplies, you will notice on blocks of color (like the calibration prints) that every block has a sharp, darker edge. You won't change that. New consumables may fill in the color block better, but guaranteed, one edge will always be darker.
                  Congratulation for noticing. =^..^=
