Taskalfa TA2552Ci
  • melmar
    • Aug 2011
    • 43
    [CQ] Taskalfa TA2552Ci
    Im having print quality problems with a TA2552Ci.
    If I print a cyan test page from service mode the output is Cyan, if I copy a cyan page the output is cyan. However if i print a 100% cyan page the out put is dark blue.
    I have tried a KX and PDL driver also via USB all with poor results.
    Does anyone have any thoughts as to why printing is not producing good colour reproduction.
    thanks in advance
  • JVergin
    Service Tech / IT Rep
    • 216
    Re: Taskalfa TA2552Ci
    Check out the color table profiles for printing in U485. Select RH for your print color table 1 as RH seems to give the best blues. This will also slightly change your other colors too though. If it doesn't look good, Play around with other color tables until you find the one that looks best!
    the print color table 1 is what will print by default.
    print color table 2 is what will print if you go printing preferences -> imaging tab -> color reproduction dropdown -> Custom table.
    We generally set RH for print color table 1 and CA for print color table 2.
      • 22930
      How many clicks on your consumables? Have you done a color calibration? =^..^=
      • melmar
        • Aug 2011
        • 43
        The machine is brand new install and yes it has been calibrated. The copy reproduction is accurate.
        • Ropariva
          • 629
          Hi
          I had a client two weeks ago with the same issue. Their corporate colour would copy perfectly, but when printed was described as "too warm" by their graphics department.
          They created a PDF for me to demonstrate. It consisted of four patches of 100% C, M , Y and K plus a large patch of their Pantone colour.
          When printed, the results were terrible.
          I changed the colour table to KO for this client and they were happy with the reproduction of the four colours and the Pantone.
          It was disturbing how poorly the machine printed these colours on the standard Kyo table.
          I have sent samples to our local Kyocera support team for their comment. I will advise of their reply.
          • melmar
            • Aug 2011
            • 43
            Originally posted by Ropariva
            Hi
            Thanks for your advise, I have been able to try it today and the advise worked perfectly.
            Many thanks
            • Ropariva
              • 629
              Many thanks
              You can also try the Colour Optimizer plug in for the KX driver if you have a specific colour you are trying to match.
              • melmar
                • Aug 2011
                • 43
                Many thanks for the advice, do you have a link to the optimizer thatyou can post.
                Cheers
                • Ropariva
                  • 629
                  You'll need to run the PostSetup.exe and add the Optimizer as a plug in. You will find it in the KX driver in the Utility/PostInstall folder. You will also need to download the print driver manual from the Kyocera web site in order to get the most out of it.
                  It allows you to use the eye dropper to choose the colour you need to reproduce, print out a chart to compare colours and then input the code for the swatch that matches your colour. I'd suggest you have a play with this at your office before going on site with it.
                  Good luck.
                  • melmar
                    • Aug 2011
                    • 43
                    Good luck.
                    Thanks, will give this a go.
