Kyocera - Fleet Services
  • Tonerkiller
    • Oct 2012
    • 668
    #31
    Re: Kyocera - Fleet Services
    Originally posted by kuby
    The problem is when I try and "Put in the correct URL and code for your KFS account and it should connect right up. " and press Submit I get the "Cannot register to the server.
    Remote services communication error.
    200"
    error when trying to get it to connect for the Remote Services
    I have had a couple of machine fall off of KFS lately and I have had a couple of machines give me that 200 code. I feel that this is a KFS issue.
    • kuby
      • Oct 2007
      • 1396
      #32
      All firmware is up to date and the latest Gateway is running. Directly connected machines, via the network, are going Off-Line also.
      • kuby
        • Oct 2007
        • 1396
        #33
        Trying to ADD Devices today and am getting a error: The connection status with Manager is offline.
        Put the gateway on a customers computer and getting this error and also on my work computer. Is this a KFS problem on Kyocera's end?
        • kuby
          • Oct 2007
          • 1396
          #34
          Seems to be working now. Guess they must have fixed it.
          • djwhoo
            • Aug 2013
            • 117
            #35
            Hey guys. How do you reregister a machine? The remote services is on but is offline and i everything is greyed out soni cant make any changes. The machine is actually online and dns settings Re correct.
            The machine was obviously registered before but i cant reregister it.
            I have already created kfs customer and i do have the access code
            help!!
            • kuby
              • Oct 2007
              • 1396
              #36
              Go into the Network setting and verify IP address. Make sure you turn off DHCP and Auto IP after you verify address. (this way the machine can not grab another IP address, also it that is an issue I suggest setting you machine up on something out of DHCP range like 30 to 40). Make sure you have the domain input in the machine also. Also verify that the Access Code in input in the machine and sometimes I re-input it just to make sure. Then after you have all the setting correct try restarting the machine.
              Note:
              You do not have to install the Kyocera Gateway to get Kyocera machines of show up on your KFS, this is just for none Kyocera machines.
              • tmaged
                Owner/Service Manager
                • 1873
                #37
                You have to call Kyocera & have them do it. If a machine was previously registered, you can default the settings in U520, but if the installing dealer never deleted it from their account, Kyocera has to get them to remove it.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                • sostek
                  • May 2010
                  • 80
                  #38
                  FYI, most KFS connection issues I've been able to resolve with; 1-DNS-google 8.8.8.8, 2-firmware. We have only a handfull which won't connect at all. Hope this helps.
                  Scott
                  • Necrocannibal
                    • May 2008
                    • 212
                    #39
                    Does anyone know the username and password for the gateway? I was almost positive it was admin and admin1234 but those aren't working.
                    • darry1322
                      • Oct 2010
                      • 817
                      #40
                      admin
                      admin#1234
                      • Has Been
                        • Nov 2012
                        • 48
                        #41
                        Everything working OK, but how do you keep the machines from going OFF LINE. Both Kyocera and the others show that they are reporting to be OFF LINE under KFS when I can print to them with not problem. . Is there a setting that will keep them ON LINE and not reporting that they are OFF LINE?
                        Set weekly timers to Sunday.....Off 2300 on 2303...should bring them back online.
                        • GeneOR95
                          • Feb 2018
                          • 161
                          #42
                          In U520 if you go to Setting: On/Off Config > and select off, Off Disables TDRS and allows you to re-register the device without any intervention from Kyocera. It resets the KFS status to factory like new status.
                          • tmaged
                            • 1873
                            #43
                            Slowly reread my post. If the original dealer doesn't delete the machine from the KFS system, you won't be able to register it. When you try, after reinitializing U520, KFS knows the machine already exists in the database. You have to get them to delete it from KFS so you can register it.
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            • GeneOR95
                              • Feb 2018
                              • 161
                              #44
                              I have done this numerous times and was able to register the equipment as new. You do not need the other dealer to do anything. We purchased quite a few Kyocera "Kick Off" machines that were on the Kyocera show fleet services system. The tech rep advised me to use the U520 to clear them and it works.
                              • tmaged
                                • 1873
                                #45
                                I've tried twice, and you still don't get it.................
                                Hope that helps !
                                -Tony
                                www.dtios.com
