Kyocera C2626mfp - Keeps saying toner not inserted correctly
  • deserttech99
    • Jun 2013
    • 33
    Customer is using OEM toner. Doesn't appear to be a chip of any kind on the toner cartridge but machine kept displaying this error until I replaced the Cyan ctg. Error doesn't say which ctg is not seated correctly, had to find out one at a time. Same problem happened a month ago with yellow. After removing and reinstalling it several times the error went away. Not finding any bulletins or anything on this
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera C2626mfp - Keeps saying toner not inserted correctly
    There is a 35 pages bulletin that covers this problem (plus several other problems). You need to order GEMINI MODIFICATION KIT that is rather cheap, but takes 8-10 hours to replace.
    Good luck.
    • darry1322
      • Oct 2010
      • 817
      I did one of these kits on the printer version. Picked the machine up at 4pm the day before, started at 8am the next morning and finished at 4pm that afternoon . It definitely takes a full work day to get it done.
      • Scottb
        • Apr 2013
        • 306
        Oh yes this is a fun job, be sure to pack a breakfast, lunch and quite possible dinner.
        • Geo
          • 662
          I'll bet that "deserttech99 " thinks we are kidding ..
            • 23009
            I had 9 hours in the first one. With some practice and self written instructions I got it down to 6 hours. That's without the cell ringing every quarter hour. =^..^=
            • JR2ALTA
              • Feb 2010
              • 2033
              Isn't that bulletin for "add toner" message?
              • deserttech99
                • Jun 2013
                • 33
                Good luck.
                Do you have a part number on this?
                  • 23009
                  Search "Gemini Modifications". It's posted here somewhere. =^..^=
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1889
                    Technical Bulletin #2 for the 2126 adresses this. If that doesn't work, you'll have to do all of the updates in Tech Bulletin #2 for the 2626.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
