Kyocera 300I/ Copystar CS300I adf problem
  • axyun
    • Aug 2007
    • 1323
    Copystar CS300I documents feed but make a buckling sound when document has fed and is turning and after about 10 documents may jam and crumple up / wrinkle document.
    Nothing appears to be in path as I have pushed thru cardstock manually . I have never worked on this document processor(DP670b) and could not see how to remove covers. Downloaded service manual for DP670 but that
    does not show disassembly. Did not want to waste time in customer's office and figured after downloading manual I would have disassembly procedure. I see from parts manual there ate tabs on covers. I guess I want to
    take them off to get to transports assembly so i9 can see what is happening. Any help is appreciated. Frank
    • 23009
    Re: Kyocera 300I/ Copystar CS300I adf problem
    What jam codes? =^..^=
    • qtech
      • Jul 2009
      • 41
      See this thread..........
      http://www.copytechnet.com/forums/ky...-300i+adf+jams
      • axyun
        • Aug 2007
        • 1323
        Thanks David. Most of the time the documents don't jam. When they do they exi to glass with serious creasing.
        I Think it may require the modification for jamming/skewing that Qtech has supplied the service bulletin (027)
        Thanks Qtech
        • Geo
          • 662
          Remove and reinstall the original white plate...If the plate is too far left it will interfere with the guide fingers and cause the paper to hang up...And of course check for nicks and any mylars that may be bent...
          Have fun..
          • axyun
            • Aug 2007
            • 1323
            Thanks Geo.
            • daveh12
              • Jul 2012
              • 157
              Originally posted by qtech
              This is definitely the problem. It is very common with this type of document processor. Either a new hinge or the extra mylars as in the above thread.
              • axyun
                • Aug 2007
                • 1323
                thanks Dave.
                • ss12
                  • Jul 2008
                  • 289
                  I've adjusted the screw on the hinge previously with good results
                  • axyun
                    • Aug 2007
                    • 1323
                    thanks for that s12. i will be going with the mylars when they arrive so i will have them if necessary. frank
                    • Scott
                      • 196
                      Have had very little luck replacing mylars
                      • darry1322
                        • Oct 2010
                        • 817
                        All of mine with this issue were fixed by adding the mylar mod.
                        • axyun
                          • Aug 2007
                          • 1323
                          Thankl you fro your info Scott and Darry. Waiting for parts. Should arrive on Wednesday. Frank
                          • axyun
                            • Aug 2007
                            • 1323
                            After changing mylars the feeder worked significantly better but not perfectly. Hinges were okay. Told customer if problem
                            recurred i would look to change feeder. Thanks to all. Frank
                            • gkalchik
                              • Jul 2017
                              • 19
                              I agree that the hinge could be the issue. I had this once but on mine someone installed the wrong hinge . It was doing exactly as you describe.
