CS 306ci-CS456ci hash marks
  • itchyfinger@att.net
    • Oct 2017
    • 77
    Hello guys
    Getting hash marks around the circumference of the black drums. firmware up to date, Sim 100 has been change for aging from 0 to 1. New style drums installed. tech support has no more ideas and have sent e-mail to our regional tech rep.
    Anyone one found out how to correct this yet?
    Itchy
  • sparkycivic
    • Apr 2017
    • 348
    Re: CS 306ci-CS456ci hash marks
    whats it look like?
    • Santander
      • May 2009
      • 768
      Originally posted by itchyfinger@att.net
      Hello guys
      Itchy
      First, agree with Sparkycivic, what do they look like? Second, do they occur on a machine generated page such as a status page? Have you swapped the main charge with one of the other colors [yellow would be a good choice], drums and charge units are all the same regardless of the color. Without seeing what the "hash" marks look like, this would be a good starting point.
      • Luther
        • May 2006
        • 682
        This is an ongoing problem for us also, seems to only happen to the black drum, have done all recommended things from kyocera and we still get the hash marks, i would love to know if anyone has found a solution also, did 3 calls in the last 2 days with those marks, sometimes replacing the drum with new style helps other times it doesn't ,they seem to reappear within 10-15 k copies
        • ntbann
          • Jan 2012
          • 628
          I have seen this also. Some times you can clean the markes from the drum others have to be replaced.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1888
            Yes, the updated drums & U100 change fixes some, but not all. IMO it's wax build up from the toner. I think that will be the next change.
            The M6535cidn line has the same issue, with the black drum.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
              • Oct 2017
              • 77
              Originally posted by sparkycivic
              whats it look like?
              hash marks around circumference of drum (----) no told replace dev with new drum and make sure firmware up to date
              • progoffice
                • Nov 2008
                • 336
                We have several of these machines doing this as well. So far it's only been on the black drums. We don't have any 406ci machines in the field. Are these also experiencing this issue? It sounds like the drums are back ordered until mid November - which is usually the sign of widespread problem. I could be wrong, but I thought the 406ci machines used the higher quality ceramic drums Kyocera is known for, the other models do not. If the 406ci is immune to this issue, perhaps the fix is manufacturing the black drums for the other models using the ceramic drum.
                • tmaged
                  • Oct 2008
                  • 1888
                  You're correct, it seems to be the OPC drums only having the issue. Same with the M6535cidn line, it uses OPC as well.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • tmaged
                    • Oct 2008
                    • 1888
                    302R493053 is the number for the new drum unit coming out. They changed the blade on this one.
                    Hope that helps !
                    -Tony
                    www.dtios.com
