Latest FS-C5300DN Firmware
  • wkmiller
    • Jul 2025
    Am looking to upgrade a Kyocera Cassiopeia Model FS-C5300DN to latest firmware.
    Currently has 07.00.0020 (2011-05-16)
    I checked ftp://ftp.kdaconnect.com/ and it has a 5350DN Individual Firmware
    Folder with an Engine and Main folder within that each contain a zip file which has bin/hex files.
    The date is 2/26/13. Files: Engine S2K8_1000006001 and Main S2K83000004005
    1.) Can I use these for the FS-C5300DN?
    2.) Would I just put the files on a USB drive and turn on the printer to update the firmware?
    3.) Is there any firmware for the FS-C5300DN more recent then that?
    Thanks!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5014
    Re: Latest FS-C5300DN Firmware
    1.) Can I use these for the FS-C5300DN? No.
    2.) Would I just put the files on a USB drive and turn on the printer to update the firmware? Yes.
    3.) Is there any firmware for the FS-C5300DN more recent then that? No.
    • vitor_bge
      • Jun 2017
      • 2
      Hi,
      Does anyone have the latest files for firmware upgrade?
      I am having some problem calibrating the colors they appear out of aligment.
      My current firmware is:
      Main: 2HN_3000.006.003
      Mechanism: 2HN_1000.008.002
      • copier tech
        • 8145
        Originally posted by vitor_bge
        Hi,
        Sure we can supply the latest firmware if you're stuck.
        This was a common issue on this engine, try cleaning the patch sensors & if the transfer belt is over life replace it.
        Firmware Update - Printer & Copier Firmware
        • KYO_OEM
          • Aug 2011
          • 715
          check Bulletin and print enclosed 2HL_CL Reg-init.capt file
          copy and paste this file to mainroot from usb key.
          Insert key and select print.
          System won`t print, system will reset reg data automatically
