DF-7120 J6511
  • progoffice
    • Nov 2008
    • 334
    #61
    Re: DF-7120 J6511
    Originally posted by kuby
    Have installed 5 kits so far, gets faster each time. So far so good and no complaints from the customers. That is a PLUS.
    What "kits" are you referring too, and are you having to do this on brand new finishers? We're still seeing lots of finisher jams - even on brand new machines. Kyocera says we're the only ones, maybe I should send them this thread.
    • skinnypuppy
      CopierJanitor/Geargluer
      • May 2008
      • 85
      #62
      I have had a number of 4 series machines throwing finisher codes on DF 7120 I have found a couple of things that may be of use. 1 make sure the stack height mod per black cat (2mm higher on tray 3 and 4) has been done. 2 Adjust fuser temp 161 down by 10 degrees under the print section of 161 fuser adjustment The jams were mainly happening after a prolonged period of sleep by the MFP
