DF-7120 J6511
  • allstar59
    • Oct 2012
    • 67
    #31
    Re: DF-7120 J6511
    Originally posted by nathicana
    On the 7120 I removed the tray motor and lowered the tray so I could remove the two pieces I marked in the attached picture. In parts listing they are in figure 2. Maybe you have already done that.
    I also removed the top cover and whatever plate was under it so there was plenty of open space from above.
    I have removed all that. The part I'm not sure about is that thin shiny metal guide (#69 - guide paper stopper) that hooks to the guide middle tray on the stapler side and then up to the roller above it. Did You have to take all that out?
    I can wiggle the assembly but that's holding it in.
    • nathicana
      • Aug 2008
      • 335
      #32
      Re: DF-7120 J6511
      The shiny metal guide comes out along with that whole bundle eject assembly. I know it looks like it won't but there is no other way.
      Remove the parts from the shaft in front and rear so you can move it as freely as possible. I may have removed items 58 and 59 also.
      Work the shaft to the rear of the finisher and find the angle where you can get the front of the shaft free of the frame and the assembly comes out.
      Take note how the wiring is routed.
      Once you get the section out you will have to separate item 63 so you can install the new style sensor and wiring. The belts will come off the pulleys. When reassembling you will slip the belts back on the pulleys after snapping everything together making sure the belts are laying correctly with the front and rear cursors in phase. I mention this because it was challenging for me.
      I included a picture of the section that comes out in one piece including the shiny metal guide
      There is another post suggesting a firmware fix for this problem. You've probably already tried that.
      • allstar59
        • Oct 2012
        • 67
        #33
        Re: DF-7120 J6511
        I'm stripping it down right now. Did you remove the staple unit or bring it out the exit side?
        • nathicana
          • Aug 2008
          • 335
          #34
          Re: DF-7120 J6511
          I may have removed the stapler but not the whole track with the FFC. It came out upward and toward the exit as I remember.
          • allstar59
            • Oct 2012
            • 67
            #35
            Re: DF-7120 J6511
            Thanks, I just got the unit out and ready to open it up
            Thanks so much for all your help
            • allstar59
              • Oct 2012
              • 67
              #36
              Re: DF-7120 J6511
              nathicana thanks for all your help! It took me three hours to get it done but it worked perfectly when I took it back this morning. Hopefully that fix will take care of the j6511 jams. Thanks again, Jim
              • nathicana
                • Aug 2008
                • 335
                #37
                Re: DF-7120 J6511
                Congratulations!
                Three hours is reasonable for that job.
                • toddanderson
                  • Dec 2005
                  • 238
                  #38
                  Re: DF-7120 J6511
                  what did you do or replace that took 3 hours ?
                  • nathicana
                    • Aug 2008
                    • 335
                    #39
                    Re: DF-7120 J6511
                    There is a style change to the bundle eject sensor and wiring in the DF-7110 and DF-7120 finishers.
                    See QA H020 for more information
                    It is an arduous job that I hope I don't ever do again.
                    It was recommended to our field tech by a Kyocera rep to address j6510, j6511
                    • tmaged
                      Owner/Service Manager
                      • Oct 2008
                      • 1896
                      #40
                      Re: DF-7120 J6511
                      Did H020 updates resolve the J6511 for you guys ? The machines that we had that were having issues were replaced, but I now have more with the jam code.
                      Thanks !
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                      • toddanderson
                        • Dec 2005
                        • 238
                        #41
                        Re: DF-7120 J6511
                        I just added a shim to that open/close switch seemed to help
                        Thanks !
                          • 23010
                          #42
                          Re: DF-7120 J6511
                          I ordered up the bulletin parts and got 5 of them immediately. The optical switch is still on backorder. In the meantime the customer bought a new machine, so this machine is parked amongst our lease returns.
                          • tmaged
                            • Oct 2008
                            • 1896
                            #43
                            Re: DF-7120 J6511
                            Interested to see how you accomplished it. The DF-770 ran good and didn't have any issues after the initial updates. It baffles me why they would make a change and screw it up with the DF-7120 ?
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            • tmaged
                              • Oct 2008
                              • 1896
                              #44
                              Re: DF-7120 J6511
                              Here's my attempt at the shimming. We'll see how it goes.
                              Hope that helps !
                              -Tony
                              www.dtios.com
                              • tmaged
                                • Oct 2008
                                • 1896
                                #45
                                Re: DF-7120 J6511
                                So, wondering why we never saw this issue on the DF-770, I stripped one down to check it out. Just as I guessed, Kyocera created a problem that didn't exist. That sensor was not on the DF-770, which is pretty much an identical finisher, that was out for 6 years or so.
                                Hope that helps !
                                -Tony
                                www.dtios.com
