Kyocera fuser jams
  • JR2ALTA
    • Feb 2010
    • 2028
    Kyocera fuser jams
    I've had to adjust lead margin for fuser jams on full page, solid color pictures on a cs6052ci. They jam nasty and there appears to be no dial or pressure release that allows customer to at least attempt their own removal. We don't sell a lot of full size Kyocera so possibly there's a procedure I'm not aware of?
    Thanks in advance.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1859
    Re: Kyocera fuser jams
    You probably know this, but running either 8-1/2x11 R or on heavier paper will remedy the issue.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • JR2ALTA
      • Feb 2010
      • 2028
      I believe, I hope, I remedied it by increasing the leading edge. It was seriously 2mm from edge out of box.
      Besides, r direction doesn't work well with LCC.
      I was just surprised there was no way to remove paper without ripping it to shreds. Maybe the fuser has a retraction setting or something. Admittedly, when this type of jam occurs the paper travels underneath the metal guide plate
        • 22936
        2mm is not enough void for 300% fill. 3.5mm to 5.0mm void is better for heavy fill. =^..^=
        • JR2ALTA
          • Feb 2010
          • 2028
          Thanks. I wish I had re-worded my post. I was mainly lamenting the lack of jam removal aides in the fuser section.
          • habik
            • 2013
            The fuser has only disengage mechanism from main drive. Once rolled up. You gotta strip it out. Its lame, I know but that's how it is unfortunately.
            Firmwares HERE
            • eddie110171
              • May 2012
              • 133
              Sometimes it's easier to just pull the fuser and remove the jam.
