Kyocera PF 730 feed rollers
  • tech28
    • Jun 2013
    • 434
    Anybody have a source for these feed rollers for this lower unit?? Other than China?
    • 23007
    Re: Kyocera PF 730 feed rollers
    Like this?:
    Kyocera TASKalfa 3051ci Paper Feed Components
    • tech28
      • Jun 2013
      • 434
      They are Part # 2K906010, Set of 3, the 6230,6080,6350,6360,6370, don't work, hair different.
      • JR2ALTA
        • Feb 2010
        • 2033
        Are you saying the rubber diameter is different or just the hub?
          • 23007
          I think I'd make a visual comparison to the Konica Minolta neoprene rollers. I would be surprised if they didn't fit. You might have to press the rubber onto the old hubs. [1] A5C1 5622 00, [2] A00J 5636 00
          • tech28
            • Jun 2013
            • 434
            Ordered from E Bay, 20 bucks for 2 sets(China), should get sometime in next 2 weeks, Thanks for the response guys. Will let you know how they work out.
            • JR2ALTA
              • Feb 2010
              • 2033
              What we're saying is that it's common practice to swap rollers (bare rubber) onto different hubs.
              • tech28
                • Jun 2013
                • 434
                Have done that in the past, thanks for the reminder though, Also thought about streachies, but thinking might throw timing off. Might have to experiment. Thanks for all the replies. have a good weekend!
