Kyocera 3501i duplex issue
  • dalewb74
    • Feb 2018
    • 1153
    [Misc] Kyocera 3501i duplex issue
    from time to time when running a duplex job you get a message about 2 sided copies can't be combined. there is no exact error code listed. the firmware is up to date. if you 906 it the message goes away for 3 or 4 days, then returns.
    • 23008
    Re: Kyocera 3501i duplex issue
    Take a look at the Event Log to see what error is recorded. =^..^=
    • dalewb74
      • Feb 2018
      • 1153
      the machine says can not make 2 sided copies due to failure. when trying to print event log it gives paper jams, service call log, maintenance log, unknown toner log. it doesnt show a failure log and it doesnt give a code.
      • Geo
        • 662
        The problem is with the doc feeder ,duplex function is failing. Do the usual firmware update, check and reset all Doc feeder connectors and interface PCB . Also do a HDD scandisk and reformat. Make sure you first do a 917 if needed to backup and restore HDD data.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1887
          Clean the white roller. It's what the CIS looks at to do white reference. If it doesn't see the white level it should, it disables the CIS,
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • dalewb74
            • Feb 2018
            • 1153
            firmware was first thing updated. all connections for the adf have been unplugged and reseated to make certain everything was connected properly. have been through the service manual trying to find something related to the issue with no luck. have tried searching google as well with the same results. hence why i posted here was to pick a few brains. what gets me is it doesnt show a C code. so kinda hard to pinpoint exactly whats going on. any help is greatly appreciated. thanks for the input everyone. will try the things suggested that i havent tried so far.
            • Geo
              • 662
              Definitely do the HDD...
                • 23008
                Just answer one question: Did you print the event log? =^..^=
                • wragsdale
                  • Jul 2014
                  • 188
                  The service call log lists failure codes. Additionally, U904 will list total and recent failure codes.
                  • TonerEater
                    • Dec 2017
                    • 10
                    When any error is followed by "due to a failure", I would try u906 Partial Control. Reboot machine. If error appears again, make duplex copies on the platen. Then use the Document Processor. If it works on the platen but not through the DP, clean the Size Detection PWB under the original tray. A misdetection of original size could be causing the "Cannot be Combined" error.
