KM-3050 from a wholesaler
  • Jimbo1
    • Mar 2008
    • 845
    Ok we got this 3050 from a wholesaler with about 50k on it.
    We are trying to track down a shading problem from front to rear that is there whether print or copy..
    It's lighter in the rear than the front.
    We have installed new drum-dev-transfer-main charge.
    Anybody got any ideas. Ever seen the laser do this?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • aragul
    • Dec 2007
    • 128
    I've seen a main charge cleaner cause this by pushing the front end of the main charge away from the drum. You can throw in a Falcon 1-2 main charge to rule out the cleaner.
    It was our first Falcon 3, and I was already frustrated with the horrible response time from the interface when we saw the excellent shaded prints. Disassembling the cleaner and messing with the gears fixed it.
    • Jimbo1
      • Mar 2008
      • 845
      We have swapped in a whole new main charge unit and it still does it.
      Cdr. William Riker
      • Jimbo1
        • Mar 2008
        • 845
        Never mind. We discovered someone got the charge units mixed up.
        Thanks to all.
        Cdr. William Riker
          • 23010
          This happens on all the Stratos and Falcon machines. Only one customer in 100 actually reads the instructions, and tries to clean the primary. If the cleaner isn't positioned exactly right..... =^..^=
          • Hose1cook
            Defective Technician
            • Jun 2008
            • 80
            Stratos? What models are these? Thanks
              • 23010
              KM-2540, KM-3040, KM-2650, kKM-3060. =^..^=
              • Hose1cook
                • Jun 2008
                • 80
                OK Thanks, did not know that. Have to say, I'm not liking them too much, lots of electronic problems and those DF-670's leave a lot to be desired.
                • Jimbo1
                  • Mar 2008
                  • 845
                  I just picked up my cert on the Stratos.
                  I didn't like when they went from Falcon 2 to 3 the silliness where they made it a little moe difficult to network.
                  The Falcon II is a breeze.
                  Cdr. William Riker
                  • Metalvoc
                    • Sep 2008
                    • 155
                    I kind of like the new silliness. It was a bit difficult to pick up at first, especially if you were used to networking the 2s, but the new system is a lot more versatile in it's networking capabilities.
                    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
