FS 8520 Banding Colors, Should I replace drums and developer or machine ?
  • Doug James
    • Jan 2012
    • 935
    [CQ] FS 8520 Banding Colors, Should I replace drums and developer or machine ?
    This machine is calling for maintenance kit B and Banding colors (See pic). Should I install it or replace machine... Thanks so much
    • 22999
    Re: FS 8520 Banding Colors, Should I replace drums and developer or machine ?
    My guess is that you've got a broken yellow developer spacer. When the yellow drum gets too close to the yellow mag roller the developing roller will arc to the drum, shutting down the HVT momentarily. When the primary charge drops out you'll get a bar of C, M, Y, and K.
    Why do I think it's yellow? Well it could be any color ... but that yellow feature at the right of your page is an incomplete yellow bar that did not cause the HVT to completely drop out. =^..^=
    • Doug James
      • Jan 2012
      • 935
      I believe you nailed it. THANKS SO MUCH !!! Going to order Drum developer for all the colors. It boggles my mind how much insight you have on these machines. I so appreciate your help !!!
        BlackCat like many other Techs here are very helpful...Just be sure to " Like " and " Thank " someone that has provided a proper fix. This is the way that we techs build our " Rep " here.
          • 22999
          Another way you can express your appreciation is to help others with your experience. And you will get that experience, just takes some time and persistence.
          I give extra consideration to those that can be seen offering their advice, and take the time to gather accurate complete observations. So far so good. =^..^=
          • Ropariva
            • 655
