Ecosys M6526 cidn noise
  • vstar
    • Aug 2007
    • 176
    We are a Lanier dealer but a new customer asked us to look at this unit. It was working fine last Thursday and when they came in Friday morning the machine made a loud grinding noise and popped an error code of 2820.
    I looked up the code and it says a fuser motor error, is this correct, and is there anything in particular that everyone has seen on this model that can cause that?
    Thanks for any help.
    Cameron
  • masterchill
    • Jul 2005
    • 100
    Re: Ecosys M6526 cidn noise
    Most likely the fuser locked up and needs to be replaced. Have replaced a few of these. These can be a bit of a booger to get out if the fuser pressure release is off timing.
    • Ropariva
      • 655
      To release the pressure before fitting the fuser, plug the machine and turn on. It will run the cam to release the pressure. This is in the manual. [emoji106]
      • vstar
        • Aug 2007
        • 176
        Thanks for the responses. This is the first and only one of these I have seen, so the company won't get a manual for it, so I just need to go off what you say.
        If I turn the machine on without the fuser installed does it need to be plugged in or not?
        Cameron
        • Ropariva
          • 655
          Cameron
          • vstar
            • Aug 2007
            • 176
            Thank you Ropariva, the customer finally got back to me and I have the fuser now. I will be going out today and putting it in.
            Thanks again
            Cameron
