TA-8002 belt run off
  • Ropariva
    • 663
    [CQ] TA-8002 belt run off
  • kjg
    • Mar 2009
    • 111
    Re: TA-8002 belt run off
    Question? Were both replacement Transfer assemblies the new style ones? or just the second one installed? The fact that it does not track with the old one gets me to want to focus only on the transfer assemblies themselves. please keep us posted.
      • 23003
      I have a few high volume users, but not like yours (~2M per year), so I'll be interested in your results. The first thing that I noticed is that the exit switch hasn't been changed since the AlphardI and still wears out at the 1M mark. I get better mileage out of this MacGuyver:
      • Ropariva
        • 663
        [ATTACH=CONFIG]40151[/ATTACH]
        • Geo
          • 662
          Your "MacGuyver is a brilliant quick fix. Used it many times.
          Thanks again...
          • sparkycivic
            • Apr 2017
            • 348
            Is the assembly sitting properly on in front of the spring loaded white buttons at the bottom, or on top? Maybe one of the buttons is stuck/busted?
            I always have a hard time getting that assembly to end up in the right place in relation to those buttons...
            • Ropariva
              • 663
                could the machine be unlevel front to back?
                • Ropariva
                  • 663
                  • Geo
                    • 662
                    As for the spring tension, I'm not surprised ...look at the date of manufacture and we don't know the age of the assemblies before installation, they could be several years old. Also, these springs are under constant pressure , are very weak and will deteriorate without use.
                    • Geo
                      • 662
                      Just has a thought about the belt..The door assy latches to the fuser assy. Is it possible the fuser unit is not sitting square to the frame and this is not allowing the door to latch with even front to back pressure.?
                        • 23003
                        Along these same lines: On Alphard II's I've seen customers shatter the upper latch hooks by slamming the shit out of them. Usually the symptom is "Door Open" indications. =^..^=
                        • Ropariva
                          • 663
