Kyocera P-6035 K drum unit
  • floody
    • Mar 2017
    • 37
    Hi all
    I visited a Kyocera P-6035cdn was getting no image, so I removed all the drum units and it looks like the K charge roller as melted to the PCU and managed to free itself off pulling the PCU off the drum at the same time, I will try post some pictures shortly, just wondering has anyone else had this problem?
    cheers
  • floody
    • Mar 2017
    • 37
    Re: Kyocera P-6035 K drum unit
      • 23002
      Wow! That's really nice!
      i've seen plenty of those crossfeed bars , but never was the primary melted to the drum. I thing it's reasonable to presume that you have some acing going on.
      I hope that you going to change the black drum and developing unit, then calibrate.
      • floody
        • Mar 2017
        • 37
        the K drum has done less then 500 prints in the past 2 years, to me it looks like toner has stuck to the charge roller and while its not been used its welded itself to the drum.
          no I think BlackCat is more on the right track... voltage arcing is more likely.
          • floody
            • Mar 2017
            • 37
            what would you think would cause the arcing? the machine in clean, I cant see any lose or damaged contacts or connecters
              • 23002
              We'll have no way of knowing. =^..^=
