DP-7100 on TA 5052 broken lifter plate.
  • copier tech
    • 8138
    Hi all,
    Found this part broken, is this a common issue as I a look after a lot of these xx52 models?
    Is it a quick job to replace?
    Thanks.
  • Has Been
    • Nov 2012
    • 48
    Re: DP-7100 on TA 5052 broken lifter plate.
    Hi all,
    Thanks.
    [ATTACH=CONFIG]40888[/ATTACH]
    Yes, getting more frequent.
    • kola28
      • Jul 2012
      • 12
      yup,it's a common issue on DP-7100.
      it take about 30-45mins to replace
      • copier tech
        • 8138
        Thanks, maybe i'll carry one in the van
        • George J
          • 107
          It's a somewhat common fault. There's an updated part that replaces that piece with a metal hinge. The hinge and the guide plate are a separate part though. There should be a bulletin about it.
          • Ropariva
            • 663
            Hi all,
            Thanks.
            Updated part number has the pad as well
            303R707021 GUIDE LIFT.
            • Kyo fan
              • Dec 2013
              • 368
