kyocera color printers
  • tuey
    • Apr 2014
    • 120
    looking to buy some kyocera color printers and want to avoid the models that loose registration and require total teardown to repair. i think i want to avoid the rear feed models but i dont know which of the new models feed from the rear. am i off base here in what i think i know? how do i know which models rear feed? is the registration issue a thing of the past? thanks--tuey
    • 23006
    Re: kyocera color printers
    If you stay away from the tabletop devices you should be OK. =^..^=
    • JR2ALTA
      • Feb 2010
      • 2033
      Ditto. They're all rear feed, they all drop toner on the pages. Warranty's are a bonus though.
      The registration and tear-down/toner add problem was unique to one particular POS so that's not a concern.
        • 30123
        Kyocera color suck's always has , unless you got the konica build machines for Mita years ago.
          • 23006
          The newer machines are definitely better, colorwise. =^..^=
          • tuey
            • Apr 2014
            • 120
            i'm not a big fan of kyo color either but i have a multi location customer that recently decided that she had to have kyocera everything. i sold the 5030 series, 5350 and 6030 with ok results but lost a couple with the registration thing- bought used ones and replaced rather than do the tear down. so the 5026 and 6230's are different models completely? thanks--tuey
            • copier tech
              • 8142
              I'd avoid Kyocera & go for HP a good reliable manufacturer for desktop printers for years, you'll still see really old HP's in use today.
              • JR2ALTA
                • Feb 2010
                • 2033
                HP stopped caring about servicability on their desktop models. They're throw away machines now.
                Take a look at lexmark.
                • tuey
                  • Apr 2014
                  • 120
                  agreed, the smaller new hp's are a bitch to tear down, even changing rollers got harder. i think i'll look around at the lexmark line this weekend. probably still have to sell this customer kyoceras. thanks--tuey
                  • itchyfinger@att.net
                    • Oct 2017
                    • 77
                    look at the 307ci Copystar so far we have had great luck
                    • driving lots of miles
                      • Jun 2016
                      • 398
                      The Lexmarks are also hard to work on, Most of the time you have to remove all the outer covers to work on anything. Also when you send them out you have to clean the pick up rollers before use.
