Taskalfa 2551 colour shift issue
  • temas
    • May 2011
    • 22
    [CQ] Taskalfa 2551 colour shift issue
    Please help...... I have this TA2551ci at customer's site, it jumps color as shown in the attached. I performed 464 on it and color became normal.
    After two weeks customer called again that issue re-occured. please help as this is driving me nuts!.
    Do not find fault, find a Remedy, anybody can complain.
  • copier tech
    • 8144
    Re: Taskalfa 2551 colour shift issue
    What firmware version is the machine on? & the transfer unit life count?
    • temas
      • May 2011
      • 22
      2016.03.08. i will ask a site engineer to get me the maintenance report to get the transfer belt count.
      what else should i be looking at?
      regards
      • copier tech
        • 8144
        regards
        • Geo
          • 662
          If I remember 464 has little to do with color registration....so did you perform color registration?
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1885
            On all Kyocera machines, if the density isn't correct for any of the colors, it will throw the auto registration timing out. This could be caused by any number of things, but make sure each color is nice & dark.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • temas
              • May 2011
              • 22
              can you please give a pointer to those things to look out for?
              • temas
                • May 2011
                • 22
                Registration manual or Auto?
                Auto wont work. setting manual registration is hell of a task
                464 has calibration option related to registration. this resolved the issue the 1st time. or could it be a gimmick?
                • avio2
                  • Jul 2010
                  • 150
                  read this bulletin
                  • tmaged
                    • Oct 2008
                    • 1885
                    I always start with the 089 prints. Make sure there are no light areas and that the solids are dark. Try some of the other test charts that Blackcat has posted or others.
                    Hope that helps !
                    -Tony
                    www.dtios.com
