copystar 255c doc feed quality issue
  • tuey
    • Apr 2014
    • 120
    prints fine -copies off glass great, run through doc feed and it's either gray background or blank or perfect copy. happened overnight. had large power outages/ ice storms over weekend. it's electrical i would guess but i was wondering if anyone has had similar issues? where would you start? i ran 30+ copies through doc feed when i stopped this morning with nothing consistent. thanks---tuey
  • Ropariva
    • 680
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1888
      Re: copystar 255c doc feed quality issue
      Make sure the scanner lock is not locked.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
        • 23009
        I'll confirm that. It's very easy on a Hanabi to move the machine a little and partially latch the scanner lock. It's that innocuous looking off-white lever at the left top rear corner. It's worth a look. I've done it to myself. =^..^=
        • tuey
          • Apr 2014
          • 120
          yep, thats what it was, scanner lock. have never seen those symptoms on kyocera, never forget it now. sure makes sense, but embarrassing. thank-you-- tuey
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            I had one of these that would randomly cause a grey line only thru the DP. Finally sat there and just ran the scanner back and forth in the service mode and one of the LEDs would flicker for a few seconds. I think I've had two do this so that is something to keep in mind for the future as well.
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
