km -1635
  • baderten
    • 38
    km -1635
    potocopy Do not pull paper from the bottom cabinet
  • habik
    • 2014
    Re: km -1635
    What jam code do you get?
    What is the life of rollers?
    Replacing feed+pickup+separation rollers may solve the issue ... usually.
    Jam code sure helps to pin point location.
    Sent from portable device using fast cheapset!
    Firmwares HERE
    • itchyfinger@att.net
      • Oct 2017
      • 77
      Re: km -1635
      Replacing feed+pickup+separation rollers may solve the issue ... Usually.
      oh ya jam codes and c codes would help maybe a 906 reboot
        • 22751
        Re: km -1635
        If it were me I think I would drive out to the site and maybe look at the machine. Maybe something will bite you on the ass. =^..^=
        • baderten
          • 38
          Re: km -1635
          I feel that the machine is abnormal
          When you press the print key, you try to pull the paper out of the hand side cabinet for one sheet of paper.
          If you do not put a paper stand and get out the number of j11 error code.
            • 22751
            Re: km -1635
            You should definitely try something. =^..^=
            • baderten
              • 38
              Re: km -1635
              total count 133276
              I printed the machine report and there was nothing unusual about it and I did the factory setting
              • habik
                • 2014
                Re: km -1635
                100k is about right to replace the roller kit. Bet SEP roller is flat without ribs. Modified pick roller should have black colour.
                If it doesn't feed at all...when you take the rear cover off...does it try to rotate the clutch at least? Can you see it? Clean the clutch for that tray, and assemble it back properly.
                Whilst at it. Remove the feed rollers and observe anything unusual.
                Is the pick roller sliding on the shaft and if does it mesh properly with the gear of feed roller?
                Are they not by any chance the other way around? As there is one way bearing on the feed roller meaning the shaft when turned the feed roller should lock on the shaft and start turning. Is this happening?
                Is the feed sensor arm bent or broken or missing the pullback spring?
                Is the feed sensor dirty?
                ... Can you answer ?
                Firmwares HERE
                • habik
                  • 2014
                  Re: km -1635
                  Actually...can you refrase your initial question please?
                  Do you have trouble feeding from the manual/bypass tray? Left hand side.
                  Or
                  Feeding from cassettes? Under machine.
                  Sometimes when wrong format of paper is defined for example A3 and you print on A4 it will always jam.
                  Firmwares HERE
                    • 22751
                    Re: km -1635
                    Originally posted by baderten
                    total count 133276
                    I'm done. You've just created a lot more work for yourself with this "cure-all" factory reset. =^..^=
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4306
                      Re: km -1635
                      This person has posted a few off the wall posts. Not sure if language barrier or what but I'm beginning to question if even a tech!
                      • habik
                        • 2014
                        Re: km -1635
                        Google translate does pretty decent job although I must admit I am still not sure what they really need.
                        I think it's a frustrated user.
                        Firmwares HERE
