M6535cidn vertical bands
  • nathicana
    • Aug 2008
    • 335
    This M6535cidn has a 27257 total count and has been in the field for about a year. The firmware is up to date.
    It has two bands running down the prints. The problem is intermittent but frequent.
    I replaced the transfer belt assembly, it didn't fix the problem. Kyocera suggested the secondary transfer roller so I ordered one.
    The bands line up with the ID sensors that read the calibration patches on the transfer belt. On of the examples you will notice those marks.
  • Ropariva
    • 680
    • nathicana
      • Aug 2008
      • 335
      Re: M6535cidn vertical bands
      Yes, brand new transfer belt assembly
        • 23009
        Yup, those are the color registration marks. Clearly they're not being cleaned off of the belt.
        I think that I'd clean and re-prime the transfer belt blade, then pay attention that the powder is cleaning off of the belt. =^..^=
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1888
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
            • 23009
            That's a great tip. I had disassembled a Hanabi primary transfer belt, and when I was re-assembling I could not figure out where that one extra spring came from. When the belt did not clean I knew it must be an electrical connection. =^..^=
            • nathicana
              • Aug 2008
              • 335
              Thank you for the replies.
              It was the transfer cleaning voltage terminal that was deformed not making contact with the transfer belt assembly in the fashion tmaged was describing.
