TA3050ci with noise +error code
  • axyun
    • Aug 2007
    • 1323
    Customer called about noise ans maintenance message. When I arrive the machine was no longer working. It was making a motor
    noise and error C2730. I looked up and seems to be transfer release motor error. Is this for the secondry trnsfer (roller) on right side door/conveyer unit. Please
    advise as I have little experience on this and have only changed fuser and cleaned , lubed several months ago. Maintenance is for C kit which i will look up.
    If I change whole conveyer will that solve problem. Motor sound appeared to come from rear of machine near fuser. Removed fuser and saw some wear on drive
    gear but dis not associate that with C2730 code. Any guidance is appreciated. Frank
  • buzz
    • Aug 2013
    • 288
    Re: TA3050ci with noise +error code
    I had this exact error on a 3550ci, essentially the same conveyor second transfer area. I believe the secondary transfer assembly does not come with the motor assembly. I have seen the gear on the motor shaft (located just beneath the secondary transfer assembly) get stripped out or slide off its shaft. I would take the whole right side conveyor off of its rails and inspect the str motor assembly.
    • Kyo fan
      • Dec 2013
      • 368
      That code is common for this series. One of the shafts on the plastic housing breaks:
      There are 2 gears on these shafts that spin with transfer release motor. When it breaks, you get C2730. You need to order HOUSING RELEASE DRIVE
      302K924782 and replace it. Take pictures as you disassemble it, and have a clear table for it.
      • axyun
        • Aug 2007
        • 1323
        Thanks Kyo fan. I took the unit apart(my first time) not feeling very confident and , yes the plastic shaft was broken. I suppose I
        could put it all back together again. Customer asked how much for whole conveying unit and even proceeded to call Kyocera to get
        part #. I have 302LK94022 but it is a littlle costlier that housing release drive. Save on labor charge though.
        I am unfamiliar with this machine having done only a couple of calls. I was somewhat surprised by the way the registration roller was seated on unit
        and wondering haw bushings engage when unit is mounted and is closed Frank
        • JR2ALTA
          • Feb 2010
          • 2033
          I repaired it with a long screw and nut to act as the shaft. but it didn't last.
          Blackcat had a post with all the part numbers for this rebuild. It was 5 or 6 pieces. Can't find it at the moment
          Wasn't so bad, I was nervous the first boot up though.
            • 23002
            The screw and nut typically doesn't last. I was surprised how beefy the springs are for the second transfer unit. I can't find the thread either, but here's the record out of my spreadsheet:
            "C2730" error, accompanied by gear noise. Plastic support post is broken within the secondary transfer shift drive gear pack. Gear tooth damage results. Replace Housing (302K924782), Worm Wheel 31/33 (302K924800), Gear Release 10/83 (302K924790), Release motor (302LC94190).
            Mainly it's the housing that you need. =^..^=
            • bush_tech
              • Jul 2018
              • 50
              We normally just replace the conveying unit, it's not that expensive and very quick to replace.
              • Slice
                • Nov 2022
                • 1
                Can you please help me find the 302LK94022 spare part ?
                • Kamaz
                  • Dec 2022
                  • 1
                  Thanks a lot for this thread!
                  Without all of you i'll certainly buy a new belt and a new drive for this problem
