TA 4550ci Poor Copy Quality
  • Doug James
    • Jan 2012
    • 935
    [CQ] TA 4550ci Poor Copy Quality
    I bought this machine to restore. Attached is a pic of what it's doing. No error codes. I put another transfer belt in it and ran calibration and belt timing. Did the laser glass cleaning. No change at all. Any help would be very appreciated...TA 4550ci Test Target02192019.jpg
  • Santander
    • May 2009
    • 768
    Re: TA 4550ci Poor Copy Quality
    Since you bought the unit used, does it have OEM toners? I would then try a developer refresh followed by a toner curve adjustment, both in the systems menu>adjust maintenance. You should also reset to factory defaults by running sim 002, you never know what the previous tech has done. Print out the maintenance report and make sure all the settings are at their default settings as outlined in the manual, this will give you a base setup to start working from. If you still get washed out copies and you said you replaced the transfer belt, you would have to start troubleshooting the secondary transfer. Hope this helps.
      • 23010
      Wow! That's really poor color registration! Did you do the manual color registration? You'll probably have to do so several times to get the registration reasonably close. Also make sure that the firmware is up to date. One of the updates addressed color registration variation. =^..^=
      • jper34
        • Sep 2011
        • 225
        I would check each color separate, do all the colors have the same results..try to run a copy in text only mode..that might help ..
        check copy before it gets into the fuser..there's a lot of stuff to check....but stop it before it gets into the fuser, look ..stop in the middle of a copy..how does the latent image look on the drum..good luck..mate...!!
        • JR2ALTA
          • Feb 2010
          • 2033
          You could need Dev or drum drive if they're out of sync
