TA 4550ci Smearing on rear of 1 sided copy
  • Doug James
    • Jan 2012
    • 935
    [CQ] TA 4550ci Smearing on rear of 1 sided copy
    TA Smearing on rear side of 1 sided copy. (Pic attached) I did the toner curve adjustment which has solved this problem in the past but no resolution. Any help would be very appreciated !!
  • kuby
    • Oct 2007
    • 1409
    Re: TA 4550ci Smearing on rear of 1 sided copy
    ?? Transfer belt cleaning
      • 23009
      Yes, 2nd transfer belt. Cleaning seems to help short term, but there are no separate parts of that unit, so just order the assy. =^..^=
      • Doug James
        • Jan 2012
        • 935
        Thanks so much for your help !!! Are you saying replace the paper conveying unit...
          • 23009
          No: Parts Roller Secondary Transfer SP (302LK94050).
          • Doug James
            • Jan 2012
            • 935
            Thanks so much !!!
            • Tom
              • 344
              Yes, replace the transfer belt assy. That's common on just about any color copier, but I've never seen one that bad unless it's been doing it for awhile.
              • Doug James
                • Jan 2012
                • 935
                Thanks for your response, I was afraid of that....
