KYOCERA M6026 folding paper @60mm
  • Printmend
    • Aug 2012
    • 67
    HI ALL,
    I've got a Kyocera M6026 that is folding the paper perfectly @ 60mm on every print.
    It appears to be doing it before it enters the fuser where the fold is then perfected!
    Any help greatly appreciated.
  • ntbann
    • Jan 2012
    • 628
    Re: KYOCERA M6026 folding paper @60mm
    What jam code are you getting? Hard to help with so little information! Did you check the transport sensors?
      • 23009
      aka as a paper jam? What jam code? =^..^=
      • Printmend
        • Aug 2012
        • 67
        No jam code as the page is not getting jammed.. Page comes out folded perfectly onto the exit tray
        • Ropariva
          • 680
          Sounds like you have a feed clutch not letting go and over feeding. I take it there is no print on the folded portion?
          • Printmend
            • Aug 2012
            • 67
            Please refer to images attached.
            Image M6026 show the printed page folded beside an A4/letter size sheet. This is the way it comes out of the machine, folded perfectly straight & flat with no paper jam.
            The second image M6026 1 shows the leading edge of the page printed perfectly except some of the image has transferred further down the sheet off the pressure roller where it has not fused correctly as it is not in direct contact with the upper fuser roller/ hot roller..
              • 23009
              So the implication is that the paper folded in that very narrow section between the contact with the 2nd transfer roller (primary transfer and secondary transfer are completed), and the fuser inlet guides. My guess is that the paper wraps the 2nd transfer roller briefly before being drawn into the fuser, completing the fold. Perhaps there is damage to the second transfer bushings or guides that snags the paper? =^..^=
              • Printmend
                • Aug 2012
                • 67
                OK I will check the bushings, I didn't notice anything wrong with them and rollers were rotating freely on initial inspection.
                No sign of damage to guides either.
                I will take another look and let you know how it goes.
                Thank you for your input blackcat4866
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  If it's happening consistently can't you stop the machine and check it out
