KM-3552ci K-toner won't go in
    • 23010
    It's pretty obvious I guess ... the enduser runs out of K toner. Thinking that they can get a few more prints they remove the toner, reinstall the empty, remove it, reinstall the empty, maybe 6 times. They never actually get one additional page.
    So the toner arrives, but it won't go in. It's the OEM, right type, but a small gate has dropped from the engine cover stopping the cartridge from sliding in. It's probably because of all the failed attempts. The machine is trying to protect itself from another stupid customer choice.
    I figured a way to get the cartridge slid in (strip of cardboard 1" x 15" on top of the cartridge, lifting the gate, then slid out), but there must be a proper way to retract this gate. Is there a customer way to recover from their own bad choices? =^..^=
    • 23010
    Re: KM-3552ci K-toner won't go in
    OK, I found something called "container solenoid K", U033 Solenoid Operation Check. Is that it?
    • djs9164
      • Mar 2018
      • 79
      STOP. The end user is trying to put a waste toner bottle in the black toner spot. Either that or your customer inserted the new toner into where the waste bottle goes. Find out if it's new and look toward the mouth of the bottle for a slide switch. Only do this if you are certain the toner is new and NOT a bottle full if waste toner.
      Sent from my XT1635-01 using Tapatalk
      • Ropariva
        • 703
        • JR2ALTA
          • Feb 2010
          • 2033
          Good info, but the the advice seems preventative...what's the fix?
            yeah SHOOT the user so it doesn't happen again.. drag body to dumpster... throw body in ...buy ticket to country that will not extradite you
            • FriendlyTech
              • Jan 2018
              • 30
              Simple fix, took me an hour of tearing the machine apart before I figured it out. If red is showing it won't go in the machine.
              • JVergin
                Service Tech / IT Rep
                • 216
                [ATTACH=CONFIG]42012[/ATTACH][ATTACH=CONFIG]42013[/ATTACH]
                Yep, We've had a few come from the factory like this. The bad part is the same thing will happen when a customer is attempting to insert the waste toner back into the toner slot. So, best option is to go on site and confirm it's actually a new toner.
                I had a customer swear up and down that the toner was new sealed in box but the container was dirty and filled with waste toner. I asked if there was any cardboard, plastic protector, or rolled up bubble wrap in the box and she said no. Someone put it back in the box and next to the new toner boxes.
                **Side Note - Seems obvious but I've been stressing to our customers recently to make sure they're putting the black toner in the correct way. It is possible to put it in upside down, and if they force it through, it will damage the felt on the toner hopper. We had this happen on a 5002i. We had to replace the toner hopper, and the developer unit as pieces of that felt made their way to the developer unit and it seized.
                  • 23010
                  This design assumes a higher level of intelligence than the average enduser can demonstrate. That's the only thing that I worry about. Only the top 10% of endusers are capable of doing this right ... consistently.
