KM 3060 black screen
  • adel_nathan
    • Jul 2011
    • 103
    [Dead] KM 3060 black screen
    hi every body
    i have M/C Kyocera KM3060 give black screen
    i turn it off and on again no change
    check the boat dim and ram chip , also not working
    any other Idea ?
    please help
    thanks
    • 23008
    Re: KM 3060 black screen
    I think I'd probably start with firmware. Since the screen is blank you'd best wait a full hour to be sure that the firmware finishes.
    If that doesn't work I'd do the dip switch op panel reset.
    Depending on what version operation panel PWB, it may have a separate DIMM or it may be integrated. If the DIMM is separate you can try changing the DIMM separately. If it's not separate you'll have to replace the whole operation panel PWB, then firmware.
    If that doesn't work, you might have a bad main DIMM or main controller (and firmware).
    There are many possibilities. =^..^=
