Kip WF color
  • Tonerkiller
    • Oct 2012
    • 668
    Kip WF color
    Is anyone going to sell the Kip wide format color?
  • mo0651
    • 1054
    Re: Kip WF color
    Already do!!
    • Tonerkiller
      • Oct 2012
      • 668
      Re: Kip WF color
      Originally posted by mo0651
      Already do!!
      What do you think about them?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4745
        Re: Kip WF color
        Konica Minolta dealers sell them. I've sold two Kip 860's and both doing good after about a year.
        Few years back you couldn't find a color "laser"wide format for under $50k. You can get this Kip delivered with PDF option for around $25k (cost) sell for $28 - $30k
        • kingarthur
          • 1383
          Re: Kip WF color
          I've done the training, got 2 installed and a 3rd going in soon, seem to be reliable...I've probably spooked things now
          • copyman
            Owner / Technician
            • Sep 2005
            • 4745
            Re: Kip WF color
            Also wanted to add. You should be factory trained to work on these. The setup take 8 hours over 2 days. First day machine has to be leveled with a precision water level. Check & level again 2nd day after machine settles (metal plates under feet should be used if on carpet). Then continue with setup.
            • Tonerkiller
              • Oct 2012
              • 668
              Re: Kip WF color
              I am glade to hear good things. Looks like we will be selling them once the details are worked out.
              • Tonerkiller
                • Oct 2012
                • 668
                Re: Kip WF color
                Do you set up these in the shop or at the customers location?
                • darry1322
                  • Oct 2010
                  • 817
                  Re: Kip WF color
                  Customer location. Even moving across the room you'd do the leveling all over again.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4745
                    Re: Kip WF color
                    Setup at customers office. As other poster wrote, once leveled and setup shouldn't be moved.
                    Few other things, should use 2 people to setup because of how big & heavy transfer belt is, etc.
                    and pay close attention to room size requirements. It needs a lot of room around machine to remove transfer belts drums, etc.
                    Plus it is very noisy (even when idle) so best not to have near desks. I've had complaints that people can't hear while on the phone because of it being so loud.
