kyocera 5052ci duplex jams and error c2500
  • J_B
    • Mar 2011
    • 13
    I have a machine that was jamming in the duplex and coded out with a c2500.
    It was stopping and the 2nd set of duplex drive rollers as they were not turning. I happened to have a right side unit in stock...it was partially damage in shipping. But, I was able to salvage those needed parts off the customers unit.
    Now it's still jamming in the duplex, but at different points. Mostly at the entrance now at the first set of duplex rollers.
    The paper feed motor that drives it seems to be strong and doesn't stop. All the duplex sensors test ok. It has the newest Firmware.
    Has anyone had duplex issues on the "2" series? Or encountered the c2500 error?
    Thanks for your time!
    JB
  • djs9164
    • Mar 2018
    • 79
    Re: kyocera 5052ci duplex jams and error c2500
    JB
    Good Timing. Just today C2500 on a 6052ci. Motor is turning, but I am ordering the drive unit and board. Should be installing tommorow so I will report back.
    Sent from my XT1635-01 using Tapatalk
    • djs9164
      • Mar 2018
      • 79
      Might add. On my machine I cannot reset the C2500 code so it may not be the same issue.
      • J_B
        • Mar 2011
        • 13
        Please let me know. This machine has had 7 c2500 in the last week. But, they can be reset. The code has only came up after a duplex jam.
          • 23010
          jam codes? =^..^=
          • djs9164
            • Mar 2018
            • 79
            Installed new PF drive unit ( comes with PWB attached). Machine reset and worked normally. Looks like that was it for my call. Will watch and update if needed.
            • J_B
              • Mar 2011
              • 13
              jam codes? =^..^=
              430X and 440X DU 1 & 2 since I've put on the new convey right side ass'y
              When I first went onsite it was 440X code, always jamming before the DU2...because the 2nd set of rollers were not moving.
              • J_B
                • Mar 2011
                • 13
                Thank you for the update!!
                • KYO_OEM
                  • Aug 2011
                  • 725
                  Have had similar cases in our market.
                  Mostly conveying unit clutches are related.(rusted!!)
                  DU CL1, DU CL2 or MFP clutch blocking the feed drive unit.
                  • toddanderson
                    • Dec 2005
                    • 238
                    The middle clutch may relate, some times clutch slip and only show issue in duplex mode and not single copy
                    • toddanderson
                      • Dec 2005
                      • 238
                      Maybe also look at the door switches, they can cause jamming and c2500,
                      the switch is a strange setup with the front cover and side unit. also a 2nd door switch on the top back side of the conveying unit
                      It also could relate to primary feed tires and clutch, as they can slip just enough
                      single sided works but duplex jam
